跳转到主内容
加入维修社区 - 创建账户
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
MacBook Pro 2016 doesn't turn on
My mb pro 2016 with motherboard model: 820-00281-A, doesn't turn on , I followed all videos I found trying to troubleshoot my problem but I’m stuck , all rails seems fine  ( like PP3V3_G3H  with 3.3V and PPBUS_G3H with 12.4V, PPVIN_G3H_P3V3G3H with 20V, SMC_BC_ACOK with 3V) the only anormal thing that I found is L7030 has 0V everything else looks good. Any help please? Should I replace just the coil ?.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If there is voltage on one side of the coil and not the other than it is faulty. If there is no voltage on either side it will not be faulty. Is PP5V_S0 present?
这个答案有帮助吗?
得分 2
1条评论:
There's no voltage neither pin 1 or pin 2 of the coil, I had understood that I have to had the same voltage on F7000 / 1 (~ 12.8) and on pin 2 of the coil L7030.
And I have PP5V_S0 with 0.5V. Soothing curious is that i can perceive a buzzing sound I don't know if it comes from the coil or the ssd or cpu but is around that zone.
完成的
添加一条评论
添加你的答案
Yuliano Moscoso 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 16
总计 365
