跳转到主内容
Repair guides for portable MP3 players, released first in 1997. These devices play back stored music from hard drives or flash memory.
341 个问题 查看全部
Philips go gear mix
Recently found my old mp3 player, a philips GoGear Mix 4GB and I really hope I can fix it but it doesn’t react when I plug it into my computer and press the reset button. If anyone has any advice on how to start I’d greatly appreciate it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had the same problem with mine. After running a couple of tests with the multimeter I found that the control circuit for the battery was dead. After replacing it I also cleaned the pins and made sure they were not short circuiting the board. It now works as it did before the fix was needed. Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
How did you take it apart though? I've been trying to figure that out for a while and haven't had any luck. Much thanks if you could help me out.
完成的
添加一条评论
添加你的答案
Natalia Robles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 145
