跳转到主内容
加入维修社区 - 创建账户
The HP EliteBook 850 G3 is a business-oriented laptop in HP’s EliteBook 800 series. It is from the fifth generation of HP’s EliteBooks.
Why does my display 'solerize' at odd times?
my display ‘solerizes’ at odd times - to ‘fix’ it - I either close and open the lid or reset the display refresh to another rate but neither is a permanent fix.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @bbypete128 ,
To add to the answer above, here's the maintenance and service guide for the laptop.
Go to p.76 to view the display assembly removal procedure.
This shows where the LVDS/webcam cable passes through the hinge to get from the motherboard to the display panel and webcam in the lid.
It is one place that the cable can get damaged as you said that it changes when moving the lid.
If the cable is damaged on p.26 (Item #6) you will find the part numbers for the cable.
Search online using the part number only in the search term to get results for suppliers.
这个答案有帮助吗?
得分 1
1条评论:
Jayeff,
I really appreciate your input - very complete and helpful. will download the guide and take a look at the cable - thanks again!
BBYpete
完成的
添加一条评论
最有帮助的答案
Hi @bbypete128
Some things you can try, I have a feeling the LVDS cable might be degrading or getting loose, I had encountered this weird issues on several laptops I worked with.
If it is under warranty, send in for repairs.
Else what I will try is to reseat the LVDS cable from the mainboard to the LCD Panel.
In most case it will fix the issues.
To confirm your graphic card is going well,
Here are some steps I will also do,
1. Update Graphic card drivers
2. test out with external display.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Peter Hinz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 13
总计 256
