跳转到主内容
Repair guides and support for computer monitors produced by Samsung.
What is this Samsung syncmaster EX2220 monitor LCD screen cable?
Hello!
I have an Samsung SyncMaster EX2220 type monitor.
But one of my cable connection on the LCD screen get broken. I would like to buy an other cable, but I am not sure what the type is it or where can I buy?
Maybe a backlight cable?
6 pin cables.
I can read the next information on the cable:
Black outer protect part: 125°C vw-1 Sumitube Nhr4 diam.6mm
4 white cables: E4139 6 Awm vw_1 105°C
2 black cables: Lf Hf
Thank you.
Bye.
Update (06/01/2020)
Samsung
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello, I have the same problem, I think that in any electronics store you can buy the connector that usually breaks, could you tell me the pintout of each end of the cable, especially if they are sequential? That is, if they do not have any cross pins from side to side. Thank you.
完成的
添加一条评论
4个答案
最有帮助的答案
Hi @loveparade !
I have bad news for you. I have to had buy new monitor insted of it. But of course paralell I spend months tried to fix it or looking a cable supplier. I wrote cable distrobutors with no aswer. Only one cable I think is not a value for them.
I found the name of the cable, but I could not buy it from anywhere. I do not remember the type. I found a similar that can found now:
https://www.aliexpress.com/item/32809840...
!!! But the original cable serial was slighty differnet not that I linked above: CI1406.................
I googled the screen panel and main board and any other part has got number on it and somewhere found that CI1406..................
Finally I bought that:
https://www.aliexpress.com/item/17982170...
But this cable only fitt in in the panel but not in the screen, so that was just waste of the money.
With no sucess I pressed back the broken cable end and glue it in the socket. It is worked!
But when I pressed back I have just one end borken (check my pictures above) so that can be settled in the correct space, I needed to glue to stay there.
When I tested the connection and worked, I used a heat glue gun, and glue the plastic connection into the socket/ into the screen.
Update (01/20/2021)
这个答案有帮助吗?
得分 2
1条评论:
I think I found the cable type between in my pictures.[image|2304822]
Please look after this cable and the panel or board type in google to be sure it is the right one.
完成的
添加一条评论
Hi @singleplayer ,
According to the service manual it is the backlight (or lamp) cable.
I can’t find it listed in the parts list in the manual but it must be there somewhere. Perhaps you may have better luck finding it ;-)
Once you’ve found it, search online using the part number only to get results for suppliers of the part.
这个答案有帮助吗?
得分 1
1条评论:
Dear Jayeff,
Thanks for your answer.
[image|2125792]
The Samsung was not really helpfull :(
I google a lot, I found the panel type and possible the cable type:
http://www.panelook.com/M215HW01%20VB_AU...
http://www.panelook.com/connector_modeld...
I wrote an email to the UK distributor.
We will see, what is happening.
Thanks!
完成的
添加一条评论
Hi @Zsolt Nemeth, I wanted to thank you for your reply to this topic.
What I need to know to be able to do with the hot glue is to know if the cable has any pinout order, I have the connector that has the complete tab, which is broken is the backpanel. Doesn't matter the order of the black and white cables? in position 1 is it white, 2 white 3 black, 4 black, 5 white, 6 white in the same order as the tab connector? With that I would be able to connect it. Thanks a lot
Detail of my cable.
这个答案有帮助吗?
得分 0
1条评论:
Hi!
It must be an order of the cable. I am not sure about the order, I am not an electriacan, but I think it should have the same order than in the other side of the connetor. 2 white+2 black + 2 white, and on my cable it looks like the outer white is where is a text on it. I glued to massivly so I am not able to check the cable again. I opened the monitor and make some picuter, but I was lucky, because my cable connector just broken in one side, not totally as yours.
I updated my previous post with all my pictures that I have and made it now.
完成的
添加一条评论
Hello, thanks for answering me, I have found the cable of another monitor, the difference is the final connector of the suppy and the order of the colors, it is not the same, but following the logic of the cable what I am going to do is solder that cable. I will try the same sequence that you tell me. I am attaching photos, so you can see that the backpanel connector is the same, I imagine that the standard is the same for everyone, it remains to try and pray. I'll tell you if it works after all or has pufff. Thanks a lot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zsolt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 471
