跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Optical drive preventing console from turning on
Hello there!
I bought this Xbox in used condition, but the guy who sold it to me scammed me and i couldn’t get my money back.
The console has a E100 error code, which is stopping it from even booting past the error screen. I’m guessing this is caused by the fact that the optical drive is not plugged in. The thing is that, when i plug it in and turn the console on again, it turns off in a matter of a few seconds.
This is a piece of the log provided by the hard drive:
ODDFW update sequence: 1.
FAILED to find ODD physical device, status = 0xC000000E.
GetOddPhysicalDevice failed.
COddDevice::_Open failed!
Which makes sense since its not connected.
The power supply is good, and I’ve tested the console with another known good one but the same thing happens. I’ve almost given up on the console but I want to make sure that i cant fix it before I sell its parts.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Do you know if the previous owner ever replaced the drive?
这个答案有帮助吗?
得分 1
8条评论:
No clue, sorry. I can give you some more info though. At first when I opened the optical drive the black and red cables were torn off and touching each other. I soldered them back in the right spot but it still didn't make a difference. Do you think that could've done something?
完成的
I opened it again just now and i just noticed that its missing a ribbon cable and some other part, and the only thing remaining is the pcb.
完成的
@Santiago Galvez then it sounds like they did replace it but forgot to put the ribbons in. If you can, buy another disk drive and take out the parts from that and put them in. The drive board and console boards are married so if you don't change the board when replacing the drive it won't work and the console will boot with an error to it
完成的
Heres a picture of the inside https://imgur.com/a/tTMEfIA
完成的
@Santiago Galvez yeah it's missing the cable for the laser, and it looks like the laser is missing?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Santiago Galvez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 646
