跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Computer doesn’t power on
Hi- My old but reliable, until now, MacBook Pro won’t turn on. I hope someone can help. Here are the symptoms:
  • Magsafe adapter has no light, except if the computer has been unplugged with no battery for several minutes, the adapter flashes green one time when it’s plugged back in.
  • When plugged in, the 3rd battery indicator light from the front is green. The rest are off.
  • No other signs of life.
  • I tried resetting the SMC a few times following online guides. I tried letting computer sit unplugged without battery. I tried different Magsafe adapter. I tried different battery, although one I’m unsure if works. I tried with no battery.
  • This happened the day after replacing the battery and calibrating new one (from OWC). I called OWC who couldn’t help, said bad battery couldn’t cause other symptoms, was coincidence. I am returning battery for them to test though.
Could it be bad DC-in board? I read about that part here, but it’s not clear what symptoms would indicate replacing it.
I’d really appreciate any advice. Thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
What does the onboard battery checker tell you?
这个答案有帮助吗?
得分 0
1条评论:
With battery in, or when plugged in with battery out, the 3rd battery indicator light from the front is green. The rest are off.
完成的
添加一条评论
Have you taken this computer apart?
这个答案有帮助吗?
得分 0
12条评论:
Not recently. Replaced a fan about a year ago. Added memory a few years ago, and replaced HD with SSD.
完成的
Is there a possibility that it could have shorted?
完成的
As I mentioned, I did change the battery about a day before this happened. Maybe flipping it over accelerated a deteriorating connection breaking, or something else not quite right inside? I was pretty careful though.
完成的
That seems possible, was the battery of good quality?
完成的
Yes, from OWC. I’ve bought 2 previously from them which I was happy with. Of course it could be an individual bad one. I’m sending it back for them to test.
完成的
显示更多的7条评论
添加一条评论
Hi There
The fault is a Motherboard issue and it will require to be Replaced if it don’t work please reply and I will look into it further .
thanks
这个答案有帮助吗?
得分 0
1条评论:
Thanks. Probably buying new used computer. Don’t think it’s worth trying to replace motherboard or other trial and error with a machine this old.
完成的
添加一条评论
添加你的答案
Cornfritter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 99
