跳转到主内容
All screwdrivers manufactured by iFixit and sold on iFixit.com
Why magnetizing is present only on one side of flexible holder?
Why in “iFixit 64 Bit Driver Kit” magnetizing is present only on one side of flexible holder? It is missing on side on which you attach selected bit, which makes them fall out when moved to more horizontal position.
Update (05/18/2020)
Below is image to show what I am exactly referring to:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
This is what I am talking about. The head is aluminum. There is no magnetism on that side. If you need to, use an aftermarket bit magnetizer.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If you are referring to the drive extension on the Pro Tech Toolkit, or the Mahi Driver kit, the end of the extension is aluminum (not magnetic). Push the bit into the extension all the way to hold it in place. If you need magnetism on the extension, use an aftermarket bit magnetizer, as pictured below.
这个答案有帮助吗?
得分 1
添加一条评论
I fell for this also I didn’t think of pushing it in until it clicked into place, it’s pretty obvious once it’s been pointed out but by then you’ve already revealed your/myself as an idiot🤪
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tomasz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 620
