跳转到主内容
Released in May 2018, this is a mid-range phone with a 5.6" screen and a 3000mAh battery.
7 个问题 查看全部
Why is my phone not charging?
A while ago my phone started charging slowly after i forgot it in the bathroom and i took a shower. I think a little bit of water got inside directly and more through water vapors.
I didn’t think much about it because the phone still worked fine. But after some time it started charging slowly (using all box charging equipment), i was using ampme and saw that it was charging with only a small portion of the power it was supposed to.
I didn’t do anything about it since i was a bit scared and hopeful that it was a passing thing, and than it became so bad that i let it charge overnight and it would charge only 10% and now it stopped charging at all after the battery got drained .
What part of the phone might be damaged ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
i would try a different cable first, if that doesnt solve the issue then have the charge port replaced with a genuine replacement
这个答案有帮助吗?
得分 1
添加一条评论
My phone is charge very slow and falls battery very fast.I am very upset ftom this problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nagitcgabi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 373
