跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Not recognizing new battery
I just replaced the battery in my Macbook Pro with the IFixIt kit. The installation went great and I charged the battery as suggested in the video. I then adjusted the power settings so the computer would not shut off and let it run down off the charger. This also went great. In the morning I plugged the laptop in and the charger went to orange. After a couple of hours, I turned the laptop on and it does not show a battery status. I looked at the system report and it says there is no battery installed. If I unplug the wall charger the laptop crashes. Any assistance you can provide is appreciated.
Update (05/12/2020)
I would like to add that I just put the old battery back into the laptop and it recognizes it. When I switch back to the new battery, it says there is no battery.
Update (05/13/2020)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Lets install this gem of an app CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
添加一条评论
2个答案
最有帮助的答案
@pplunkett3 - Then that tells us clearly the new battery is defective! Contact iFixit to get a replacement. But post that CoconutBattery snapshot here so you can reference to this question & answer.
这个答案有帮助吗?
得分 1
2条评论:
I will post CoconutBattery snapshot. Thank you Dan
完成的
Yep! @pplunkett3 You got a defective battery
完成的
添加一条评论
Have you tried resetting your System Management Controller? The SMC is responsible for managing battery/power-related issues on Mac devices.
  1. Shut down your Mac.
  2. On your built-in keyboard, press and hold all of these keys:
    • Shift  on the left side of your keyboard
    • Control  on the left side of your keyboard
    • Option (Alt)  on the left side of your keyboard
  3. While holding all three keys, press and hold the power button as well.
  4. Keep holding all four keys for 10 seconds.
  5. Release all keys, then press the power button to turn on your Mac.
这个答案有帮助吗?
得分 0
1条评论:
I have tried that and it does not help. I also tried resetting the PRAM.
完成的
添加一条评论
添加你的答案
Patrick Plunkett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 92
