跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
How to manage wires and cables when taking iMac apart
I want to try and fix my overheating Mac. I’ve watched lots of tutorials and think I may need to go as far as replacing the thermal paste on my CPU and graphics card. One thing that doesn’t get mentioned is how to keep track of the wires/cables and how to make sure you remember which ones goes where. I’ve seen someone using post-it strips, does anyone else have any tips for methods they use when doing this? Cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First of all photograph all wire plugs and sockets. You could then with a fine tipped marker pen number each cable plug and socket.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply Thomas, much appreciated. Do you mean mark up a print out of the photos of the wires etc? I wonder though how I will still know which wire is which when putting them back if I have only marked up a photo? It may still be hard to recognise them if they are all similar. Cheers.
完成的
添加一条评论
添加你的答案
Ben Emms 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 29
