跳转到主内容
Problem recognizing solid state drive in 2010 MacBook Pro
I have replaced the original hard drive with a Samsung 860 EVO 1TB Internal SATA Solid State Drive, and I have an external hard drive set up to install High Sierra. But when I turn on the laptop, it is not recognizing the new SSD as an option for installing the OS.
When I go into Disk Utility it lists the SSD, and it says it is not writeable, and has zero writeable space. This was a refurbished drive, but it seems like they didn’t take care of all the steps. Should I be erasing the drive and setting up a partition? Would that fix this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, you need to erase the drive through disk utility. All replacement / new drives are uninitialized / unpartitioned out of the box. Format it as Mac OS Journaled with the name Macintosh HD.
这个答案有帮助吗?
得分 1
1条评论:
Thank you! Responding now from my laptop :)
完成的
添加一条评论
添加你的答案
Rachel Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 56
总计 183
