跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
3GS SIM card reader issues
i have 4 iPhone 3gs’s with this exact issue. i tried to put the board into another housing to sell, and it no longer will read sim cards correctly. when i insert a sim card, It says No SIM in the top left, but sometimes will have carrier settings and phone number show up in settings, but those take over a minute to show up.
if i power it off and back on with the sim card installed, it will say Searching… and continue to say that even if i remove the sim card.
They all used to read sim cards perfectly before i removed the boards, but no longer will in the new housing or when i put them back into the original housings.
There is no way i damaged all 4 of them when removing from the housings/putting into the new ones. doesn’t seem to be an issue with the 2 gold bars at the bottom of the reader or the 6 gold sim card contacts.
Also, the one i’ve been messing with will now say No service, then says no sim card installed about 15 seconds after i take it out, but won’t recognize the sim being re inserted until powered off again, then it just repeats.
if you have any ideas of what the issue possibly could be, or if you need more info or photos, please let me know. thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There arw 2 things you have to check first there is a small coper strip on the logic bord right down under that have to touch the metal frame of the backhousing (step 12 at the possition of the yellow square) :
iPhone 3GS Logic Board Replacement
and second check the simcardreader if the micro switch is working when simcard is inserted.
这个答案有帮助吗?
得分 1
1条评论:
Looks like your first suggestion was the issue, most of them were bent up and didn’t fully make contact with the housing. Thanks!
完成的
添加一条评论
添加你的答案
Donny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 563
