跳转到主内容
加入维修社区 - 创建账户
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
My iPad won't turn on?
Hi!!
2017 model iPad, it won't turn on or charge.. I have put the iPad on a 24 hour charge, I have taken it off charge and then left it for a while, I have done hard reset (6-10 times) on chargeing iPad then left it an hour and then did a hard reset off charge, I have taped it on the back… I have changed the cables and plugs even socket, I have cleaned the inside of the charger bit… I need help, I am taking it to a shop on Monday fingers crossed, I just want to know any more tips?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
If you already swapped out the cables, plugs, and socket, then the problem may be a dead battery.
这个答案有帮助吗?
得分 1
2条评论:
Dead battery - broken battery and should get replaced?
完成的
Yes, try replacing the battery. It may have lost it's ability to hold a charge over time.
完成的
添加一条评论
Same here I tried them but they won't turn on and work
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ginaipad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 281
