跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
iMac won't turn on, especially with RAM sticks
iMac (late 2009) won’t turn on and here is how it works:
When I plug the cord one green LED turns on, second LED never appears
Before cleaned out RAM contacts with alcohol when I pressed power button I heard fans and hard disk sounds but no screen and no boot chime.
After I cleaned and reinstalled RAM fans run only when memory sticks weren’t installed (sometimes it run and shut down randomly) and when I have memory sticks in it fans doesn’t run, actually I hear how they try to run for a second.
What can be damaged? Power supply? Logicboard? and what it has to do with RAM? or maybe memory itself is the reason?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
So before you altered anything the system wasn't working - correct?
完成的
@danj yes it didn't. just fans and not even boot chime
完成的
添加一条评论
2个答案
最有帮助的答案
IF your system was not working from the get go, I’m suspecting the power supply has failed given the onboard diagnostics
Here's a breakdown of the onboard diagnostic LED's
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
So clearly the lack of LED #2 tells us we need to focus on the power supply first. Its also possible the logic board has a problem as well. I often find power surges and lighting strikes kill both. Are you using a good quality surge suppressor? Or better yet a UPS? Did you check the outlet to make sure the ground is properly wired and at the breaker panel make sure the ground line from it is properly bonded to either a copper water pipe leaving the house or one or more grounding rods.
这个答案有帮助吗?
得分 2
2条评论:
If there is no way lightning strike can be the issue that means there can be less chance of logicboard being also damaged?
完成的
Cross your fingers ;-} Power surges are still on the table.
完成的
添加一条评论
If the system only runs when the RAM sticks are not installed, then your RAM may be the problem. Please see if replacing the RAM sticks doesn’t help. They usually don’t need to be cleaned, and be careful to not touch the metal contacts on the bottom of the sticks.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ange Vrai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 211
