跳转到主内容
The Spin Master Boxer can be identified by the model number 6044290 and comes in the colors blue and black. The device is sold with 10 game activating cards, an IR remote control, and a USB charging cable.
Boxer is not going straight to front
I already received a new other product (Zoomer) because this problem, but my daughter still trying to play with Boxer. To the front our Boxer only goes to the left side, doing a turn, never going straight. But if I use the remote control to go back, it can go straight normally (only to the back). Is it a problem in the gears or in its circuit? I am thinking in maybe open it and try to fix. It is so nice to just let by side or throw away. Thank you. Michel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hello, just bought one doing the same. Did you ever repair yours? Trying to find a replacement motor. Thanks, Neil
完成的
添加一条评论
2个答案
Hi, it seems that it is a problem with the electrical motor on that side. Try to move a little bit the wheels from that side in front direction and see if after that the wheels are rotating.
这个答案有帮助吗?
得分 0
1条评论:
Hello. I have the same problem with my boxer bot. I found that one motor is broken but I can't find what kind of motor is using. I believe is coreless micro motor 615 but the integrated pcb board on top can't identify. Can you please tell me exactly what kind of motor is? Thank you
完成的
添加一条评论
Hi. I've managed to repair mine. The motor that is used in boxer is coreless micro motor 615. The odd thing was when I’ve replaced the motors, the boxer was going uncontrolled always on reverse. I don't know whay but after resoldering the motors and replacing the polarities (positive on boxer boat with negative on micro motor…and negative with positive) boxer is doing everythin as it supposed.
这个答案有帮助吗?
得分 0
1条评论:
Hello. Do you have the exact ref of the motor please. Thanks
完成的
添加一条评论
添加你的答案
Name 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 599
