跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Brother printers.
Brother printer can't find any SSID's.
Hello,
I have a brother ‘MFC-J4420DW’ printer, since a week or two it is unable to find any SSID/network when I try to set up the Wi-Fi.
It was connected and working before but it could not connect the Wi-Fi anymore so I tried the Inst wizard but it never shows any SSID’s anymore for any network. So it can’t be just a problem with my router/network I think. I’ve tried resetting the printer’s network settings but that also did not help.
Has anyone had similar problems or has an idea on how to fix this?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Hello I have a brother ‘MFC-J4420DW’ printer, my internet was working on my printer perfectly then we had a storm in my area and had power outages for 24 hours or more. After 24 hours the power came back on, that's when I realized my printer was not connecting to the internet.
I have tried resetting my connections but failed it doesn't show my SSID at all. All my other devices connect to my internet but my printer and Smart TV which was working perfectly prior to the power outage.
Can anyone help please?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @jonast ,
Don’t know the answer but perhaps you could check if the WLAN card is seated securely etc.
Here’s the parts reference list for the printer.
On p.13 it shows the location of part #16 which is the WLAN card.
On p.14 the part number is shown for part #16, LT3808001.
If you think that the WLAN card may be faulty, search online using the part number only in the search term of your browser to get results for suppliers of the part.
Hopefully a start.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for the help. I just tried printing with Wi-Fi direct with the printer as the group owner and that did work. So that makes me think that the WLAN card should still be ok? I’m know very experienced with networking and things like this, but I would assume that they use the same card to handle that?
完成的
Hi @jonast
How far away was the device that you connected via WiFi Direct? If it was very close by and the router is a lot further away it could be an antenna/antenna connection problem in the printer.
No other device is having connection problems with the router? Can you 'see" your network SSID with other devices or is it hidden?
The WLAN card would handle all the WiFi signals so it may be a problem with the firmware in the printer as you would think that the hardware on the mainboard would be the same for both the WLAN and WiFi Direct connections.
You could try and re-install the firmware and see if that worked.
I'm not sure if there is any firmware available because it only shows a "firmware update tool" which I think searches for any updates if available. If there aren't any I suspect that it might not show any or if it does whether it will install it if the existing firmware in the printer is the same version or even a newer version. You can only try.
完成的
添加一条评论
Printer: Brother DCP-L2550DW
Router: NETGEAR R7000P
Error: Printer can’t find the NETGEAR SSID using Setup Wizard, but could see neighbors SSIDs.
Solution: Set Brother Printer Domain Name Server number same as NETGEAR Internet Port DNS number. Run Setup Wizard, SSID is found. Enter network password. Connected.
1.  Press ▲ or ▼ to select Network, press OK.
 2.  Press ▲ or ▼ to select WLAN (for wireless connection), press OK.
 3.  Press ▲ or ▼ to select TCP/IP, press OK.
4. Press ▲ or ▼ to select DNS Server, press OK.
5. Set DNS number same as NETGEAR Internet Port DNS, press OK
6.  Press ▲ or ▼ to select Network, press OK.
7.  Press ▲ or ▼ to select WLAN (for wireless connection), press OK.
8. Press ▲ or ▼ to select Setup Wizard
9. SSID should now be found, enter network password.
NETGEAR DNS varies depending on configuration and ISP. Once logged into router see, Advanced > Setup > Internet Setup to view DNS
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jonas 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 69
总计 9,416
