跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Fans never turn on even under full CPU load
I noticed my CPU temps (idle and under light internet browsing and youtube) getting anywhere between 75-95c. I realized that the fan just never turns on, period. So I downloaded Mac Fan Control, which allowed me to manually activate fans with no problem, ruling out a bad fan. When I set fans to auto in mac fan control to observe how the computer operates under load, the rpm value on mac fan control went into the 2-3k rpm range, but the fans never actually activated. Just bought this Mac, and I need help.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try cleaning the fan. if that doesn’t work then the temperature sensor is broken and you need to fix the board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roman Baca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 28
