跳转到主内容
The Dell Inspiron 15-7569 is a 15 inch laptop with touchscreen capabilities. It’s a 2-in-1 hybrid laptop/tablet released by Dell in 2015.
3 个问题 查看全部
My Touchpad Right Click is Getting Stuck When I Tilt The Laptop?
Is there anyway to fix this, I know I could probably clean underneath the trackpad but how in detail would I need to go to fix it myself, because I am strapped on cash because of everything that is going on. Thanks for the help in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi @dev0 ,
Here’s the service manual for the laptop, taken from this webpage.
Go to p.45 to view the necessary pre-requisite steps and then the procedure to remove/replace the touchpad. This should give good access to the buttons
If it cannot be fixed, search online for Dell 7569 touchpad button board - example only to get results for suppliers. The example was shown only to give you an idea of the cost of the part. There are other suppliers that may suit you better.
If you had a USB or BT mouse lying around, you could connect it to the laptop and use that instead as an alternative workaround
这个答案有帮助吗?
得分 0
添加一条评论
Just reinstall the touchpad driver and see if the problem is solved!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Devo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 24
总计 1,178
