跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
213 个问题 查看全部
No Backlight on iMac. Next Steps?
Hi Everyone! I picked up a 2012 IMac A1418 EMC 2544.
The LCD Panel works, but there is no backlight. I am able to use a flashlight and I can see everything and it functions perfectly. AHT said no issues. The computer also can connect to an external display and everything is perfect. My question is, what are the next steps in diagnosing the issue? From my research, I am pretty sure I will have to replace the logic board. Is there anything I can/should do before doing a full logic board replacement?
Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your problem might be repairable! Check the cable is not damaged and then on the back side of your logic board is the backlight power logic, check the fuse link
U9700 - LP8561
这个答案有帮助吗?
得分 1
1条评论:
Thanks for taking the time to answer! Once I have the iMac open, I will check the cable and fuse before trying to replace the entire board. Thank you!
完成的
添加一条评论
添加你的答案
Thomas Shown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 155
