跳转到主内容
The Nikon D500 is a prosumer DSLR Camera released in January 2016.
7 个问题 查看全部
How do you repair a memory card door that is broken?
My memory card door on my D500 was a little loose, and last night snagged on the case and broke. It is still attached by way of the pin, but will not shut. Can someone point me to the way to replace the door?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is the 1 screw that holds the plate that lets it slide… it may be out of position. Without pictures, I am not sure how to fix it.
I have posted a teardown steps for removing the panel with the memory door.
Nikon D500 Memory Card Cover Disassembly
I have found a replacement part for you: https://www.aliexpress.com/item/32858030...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
S Coleman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 194
