跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
679 个问题 查看全部
Why my iPhone won't charge
Recently I just changed my battery and charging port. After installing both new parts I noticed when I used both the charging port or wireless charging it has not charged. The battery I received was dead. Is this a sign of a bad battery or charging port? Im sure it is the battery since the wireless charging and regular port is not charging the phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Make sure the battery is plugged in secure. Its not the charger if wireless charging doesn’t work either, but if the battery charges wirelessly and not wired then the charging port is also not working, try the same thing. It could also be that something else is bad in your phone, since it seems like this was not just a battery replacement for preformance and/or battery life, because you also put in a charging port, what prompted the repair?
这个答案有帮助吗?
得分 0
1条评论:
So originally the charging port was working here or there and the battery was pretty worn as well. I tried the new battery and old after the replacement of the charging port. The old battery is in an endless loop while the new battery is dead and not charging
完成的
添加一条评论
It sounds like the tristar ic is bad. I would take it to a shop and have them test it with a tristar tester. It only takes a couple of minutes and any shop should do it for free. If you need it repaired I would recommend jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com
This is usually caused from using an aftermarket charging cable that is not MFI CERTIFIED. The cheap cables don't have to chip to regulate the power input and it can spike and damage it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheGoodsGio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 114
