跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
277 个问题 查看全部
MacBook Pro not turning on after leaving to charge
Hi all, my Macbook Pro Touchbard was left to charge overnight but has since not let me switch it back on. I’ve popped in a USB C voltage meter to the ports and it’s reporting about 5.x volts and 0.01a but not sure what’s going on and why it’s not going up.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I used to have this problem with my iPad. try replacing the charging port (the piece INSIDE the device) if you are 100% positive that the charger is perfectly fine
这个答案有帮助吗?
得分 0
1条评论:
It's a Macbook Pro with 4x USB C ports, not a singular port.
完成的
添加一条评论
添加你的答案
Craig Davies 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 79
