跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
replacing/upgrading the logic board
Hi there!
The logic board of my macbook pro 15 inch mid 2014 2,2GHz (https://everymac.com/systems/apple/macbo... ) broke down and i was thinking to replace it with the logic board of the same year but with an extra graphic chip. (https://everymac.com/systems/apple/macbo...).
Should not cause any issues, right? Since they are from the same year that should work out i believe.
Thanks for the input!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Replacing the IG logic board with a DG board is a bit more than a direct drop in. The heat sink is different as well as having two fans. It can be done but keep in mind of the costs! You might find a used system which is cheaper and offers all of the pieces if you find your case or display are in better shape.
You will need to stick within the series otherwise:
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nonsense2345 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 96
