跳转到主内容
An i7 gaming laptop released in September 2017. Created to fight heat and keep air flowing with thermal engineering systems.
21 个问题 查看全部
Webcam is not detected in stock camera app, I have the latest drivers
Webcam is not detected in stock camera app, i have the latest drivers. I think my webcam is not connected to motherboard so any guide i can reach to the connector and manually attach it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Just verifying that you toggled Fn + F8 to see if the camera is being turned on and off?
If the laptop’s display works OK then the camera’s motherboard connection should also be OK as the camera circuit wiring is part of the EDP cable from the display to the motherboard.
It may either be a loose cable connection on the camera module or a faulty camera module.
Here’s the hardware maintenance manual for the laptop.
Go to p.58 to view the necessary pre-requisite steps and then the procedure to remove the web cam.
If it is determined that the camera is faulty, the part number is 5C20N00247.
If you search online using the part number only you will get results for suppliers of the part. Here’s just one supplier. It is only shown to give you an idea of what the part looks like and how much it may cost. There are others that may suit you better.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aditya Gawali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 135
