How do I upgrade from OS X 10.6.8 to 10.11 or higher?
Hi everyone!
Lame question, I suspect. I have lightly refurbished my partnerʻs A1342, except for the HD, which will be replaced with a 1TB SSD (I know the SATA 3.0 is overkill, but it is downwardly compatible, so Iʻm OK with that).
Installed full 8GB RAM, a new display, fan, speakers, battery, and trackpad. Logic board, keyboard, and optical drive still perfectly functional. She wants to pass it on to one of the grandchildren, but OS X 10.6.8 is simply not going to cut it for their needs.
How can I get 10.11.6 installed on the current drive and on a subsequent SSD upgrade (I want to make sure the A1342 wonʻt get excessively overloaded by OS demands)?
The best thing you can do here is not upgrade the OS! Leave it at El Capitan. DosDude is fun to play with its not something I would do on a system thats going to be used. The newer macOS's like Catalina really need more physical RAM and the better I series CPU's.
You also have only a SATA II (3.0 Gb/s) SATA port so what ever drive you get needs to be able to support it. Most drives today are fixed SATA III (6.0 Gb/s) and are not downwardly compatable. You need an auto sense drive like a Samsung 860 EVO Note the Interface line: "SATA 6 Gbps Interface, compatible with SATA 3 Gbps & 1.5 Gbps interfaces" It clearly supports SATA II, make sure the drive you get states it like this in the spec sheet if they don't, don't buy it!
由 Dan 完成的
