跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
Bootcamp Bluetooth Connection Issues
Hello,
I recently installed Window 10 using bootcamp in my Macbook Pro 2016. However, I discover an issue, once I boot in to windows, I can’t connect any bluetooth device.
Am I missing any drivers? Or is this an inherent issue with bootcamp 6.1 ?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Rex,
I had the exact same issue and just managed to fix it. Are you still having issues?
“I went to Windows Update, choose Optional Updates and then clicked on the Broadcom one that was available.”
The wireless devices are now connected and stay connected!
https://discussions.apple.com/thread/252...
这个答案有帮助吗?
得分 3
4条评论:
Thanks, I will try and update the drivers.
Cause currently what I do is
1. I shut down my laptop
2. Then I wait 10 seconds
3. After waiting for 10 seconds, I switch my laptop on again and proceed to hold the [option] key and switch to windows
I am not sure why does this work for me, but I believe it might have something to do with resetting some hardware in the laptop.
完成的
Yeah I still have to do that too.
I couldn’t get my devices to stay connected until I installed the “optional update”.
完成的
Hi @jordanriley,
When you boot into windows using bootcamp, does your mac give you MCA errors?
Cause when I used the computer in closed-display mode with an external display, and I try to boot into windows it will crash. I manage to get into the boot option menu, but after that it will crash every single time.
完成的
Hi @rexchlee,
I'm not getting any MCA errors but I have to have my laptop screen open when booting/using Windows. My external screen works for a minute when I first login then it switches off but after about a minute it goes back to the external display.
Don't know if this helps at all?
完成的
添加一条评论
I would contact Apple to see if there is any newer BootCamp drivers.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 2,052
