跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
The laptop doesn't see a new battery after it being replaced
Hello!
I replaced a battery in my MBP 13" E2015 using the iFixit kit/battery. The process went surprisingly smoothly. I might've had to move the new battery around a bit one time, but I don't remember me bending or folding it too much.
With the power adapter connected, the laptop boots up into OS X; keyboard, trackpad, sound - everything seems to be working okay. Except the system doesn't see a battery :)
I replaced a battery because the old one went noticeably swollen. I never had "charging" problems with the old battery.
What would you suggest me to do? Later today, I will try to remove the back panel and unplug/plug the battery connector.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery unit I got from iFixit turned out to be faulty. It had a visible “something” on the battery contact board. I tried another battery unit and the replacement went successful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anton Koval 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 31
