跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Console works only in handheld mode
I recently replaced the PI3USB chip because there was power, but no video/audio. Replaced the chip, everything works great, however now when I place it in the dock the console doesn’t show an image on the TV, but the led is solid green. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
I too have this exact same problem, I purchase a faulty switch from ebay and replaced the p13usb chip and the switch works perfectly now in handheld mode but will not dock, my next option is to replace the USB C port as I have seen this done for other issues and wondered if it may be a faulty connection to one of the hidden pads underneath. But as the switch is working I am reluctant to replace it at this stage, especially with that awful screen connector, nearly bent a pin the last time I had it apart
这个答案有帮助吗?
得分 0
2条评论:
I'm sorry to revive an old topic, but I have this same problem and I was wondering if you ever figured out how to fix yours? I checked all of the usual suspects on the board (no blown caps that I could find). Works in handheld mode but no picture on screen when docked.
Thanks!
完成的
If it docks but there is no screen output and the console charges, then pi3usb is broken or badly soldered, it is hard to align it sometimes
完成的
添加一条评论
添加你的答案
Henry Le 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 729
