跳转到主内容
Target Display Mode with iMac 2013 - only works properly per reboot
Hi all. This is yet another version of this “popular” issue.
So, here’s the thing. I have the Apple product dongle and cable between the two (thunderBolt 3 to Thunderbolt2 conversion). I reset SMC and reboot. Cmmand-F2 works the first time. If I Command-F2 is pressed again to stop Target Display Mode that works too. From then on, if Command-F2 is pressed the iMac display is barely visible with no way to increase brightness. The MacBook is aware it is there because Display Arrangement shows it as an extra display. However the touchBar only shows Brightness Control for just the MacBook this time. That is one symptom. The other one is that - after a while (!) the Command-F2 does indeed start TDM but only for a few seconds before it reverts back.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Have you ever found a solution to this problem? I have the same issue
完成的
添加一条评论
1个答案
I think you’ll need to speak with Apple on this as I don’t know if they still support it on the newer MacBook Pro’s.
Here’s a good reference: The Ins And Outs Of Your IMac's Target Display Mode
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martin Kendall 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 414
