跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 个问题 查看全部
Appliance will not power on
I decided to take the mixer (Kenwood A701A) apart to clean it up properly. The entire machine was taken apart however, all the electronics and the engine was merely removed from the housing and not interfered with The same with the gearbox. Once everything had been cleaned, ( the gearbox and engine was left as it was) the mixer was assembled without any difficulties.
Once plugged in and switched on, no response from the engine. It was just completely dead.
What do I need to look for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @prishen ,
Here’s the circuit diagram for the mixer taken from the service manual
The motor operate circuit seems fairly straightforward. Power connects through the switch to operate the motor, so most probably a wire came loose or a connection was broken when you removed the electronics.
Testing with the power disconnected using an Ohmmeter should help to track down where the problem is.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prishen Naidoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 25
总计 1,868
