跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
78 个问题 查看全部
Apple Monitor A1407 Noise
I’m having some weird noise from the back top near left. I saw the other postings’ about the monitor’s noise issue but mine is little different than them. The model is A1407. The noise comes and gradually increases and disappears frequently.
Here’s the how it sounds;
https://www.youtube.com/watch?v=Egyz03--...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I think your fan unit is caked with dust which makes it unbalanced (the source of the low thunk noise). You’ll need to open the system and try cleaning the dust out. Use s small soft paint brush and a can of can’ed air to blow the debris out. If that fails you’ll need to replace it: 27” LED Cinema Display, Apple P/N ''''''922-9358
To get into the system you’ll need to take the display off. The display is mounted in the same way as the iMac(英特尔27寸EMC 2429版本)显示器更换指南
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jama A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 149
