Replaced the battery using the ifixit guide doing every step. The phone vibrates when plugged in or when the power button is pressed, but the screen is blank.
I went through this whole process and I was really happy at how smoothly it went. Previously, I had done it for my 1st gen Pixel and I had a problem getting the screen off using a heat gun. This time, I used the iOpener and it worked great. I got the screen off without any apparent damage.
I did all the rest, no problem. I put it back together and went to test it before replacing the adhesive for the screen. I got the little vibration to let me know it turned on, but NO PICTURE! %#*@, I knew it went too smoothly.
I tried reconnecting the screen, the battery and the charging assembly connector to make sure they were on correctly. No dice. I don’t know if I accidentally disconnected something or nicked the screen circuitry when I was getting it off. I tried connecting my old Pixel 1 cracked screen to see if anything would show up, but that didn’t work either. (I’m not sure if they’re compatible, but the connector is the same.)
I tried the different reset options (power + volume down, power + volume up, long-hold power) and still no picture. Thanks for the suggestion. That's too bad. I guess I'll try a new display assembly. I'll post here on whether it works or not.
Any ideas?
由 Takashi Okimoto 完成的
@toki08 let it charge for sometime and try hard resetting it (power button & volume up button)
由 JAI GANESH NAIDU 完成的
