跳转到主内容
Repair and disassembly information for the Powerbeats Pro true-wireless earbuds. Released in May of 2019. Model number: MV6Y2LL/A, MV702LL/A, A2047.
11 个问题 查看全部
Cure for liquid damage on Powerbeats Pro?
is there any way to cure the corrosion photo on these beats connectors. Apple are charging 140, considering they’re advertised as water and sweat resistant I’m surprised they have corroded after 3 months use…
any help would be great
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have had the same issues even though mine have never ever been wet ! I am so so angry , they cost an absolute fortune on the UK and want to charge me £80 to fix them I said no and they sent them back with out the ear buds !!!! So I cannot even use the one that works . CEO letter of complaint sent !
完成的
Currently, my right ear doesn't charge anymore. I sent it back for repairs. I get the reply there is liquid damage, and that I have to pay over 100 euros to get it repaired. Powerbeats only have been used for running, so it makes sense that some sweat got inside. Total scam from Apple, don't buy these.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
The best thing to remove corrosion from surfaces where electronics are involved is gently wiping it away with a Q-Tip slightly moistened with 99%+ Isopropyl Alcohol (available from electronics parts stores).
It would be better if you could remove the battery to forestall any potential problems but since you can’t do this easily without breaking into the earbuds (see the ifixit Powerbeats Pro Teardown guide) then if you don’t moisten the Q-Tip too much i.e. not dripping and try not to bridge between the two terminals with the liquid etc, it should remove any corrosion. The alcohol will evaporate and leave no residue which could later impact on the electrical connection.
You just have to be patient and take your time and don’t let it get too wet and possibly seep into the earbuds. Allow it to dry before continuing to remove any stubborn corrosion.
Also if possible do not use “rubbing alcohol” as mostly this is <70% IPA, can contain additives and is not as effective.
这个答案有帮助吗?
得分 3
3条评论:
Thank you for your tip, I’ll give it a go
完成的
Thanks for this; I’ve had the exact same issue - the headphones have never got wet except for sweat and rain yet they’ve corroded and Apple want to charge £185 to repair!!! I’m absolutely livid.
完成的
Me too, raging
完成的
添加一条评论
添加你的答案
Jared Parker 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 69
总计 3,913
