跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
134 个问题 查看全部
MacBook Pro 13" Touch Bar 2019 - CONSTANT ISSUES? Advice needed.
Hi, I have a new 2019 13” MacBook Pro.
I bought it less than 3 months ago and Apple have had to already replaced the LCD screen due to lines across the screen (not accidental damage, just hardware defect as known as Flexgate). After receiving the MacBook back after being repaired, it is now over heating to the point it is shutting itself down.
The MacBook will become warm after 20 minutes of use, after several hours of use of simply browsing the internet it will shut itself down. I did not have this issue before the LCD screen was replaced.
I rang Apple support who checked the Diagnostics and when it came to the fan checks, they seemed to be working fine. I now am having to send the MacBook back for repairs but I have been told I run the risk of them not being able to find a fault as nothing showed on Diagnostics whilst checking over the phone and I was told I run the risk of them not finding any fault.
I don't think this is normal for a 3 month old product I have been advised that Apple will not replace the model and keep insisting that they can only repair and not replace. I'm really not happy with the current model due to its history, and if stores were open I would expect a refund or replacement, the product is clearly not fit for purpose and I have not been able to use the product for 3 weeks and counting.
Has anyone else had any similar experience with MacBook Pro 2019? I feel like I have been treated unfairly by the Trillion dollar company, Apple. I bought my MacBook on finance with the idea that it would last years, not 3 months.
I’m really feel at a loss being stuck in a credit agreement and having to deal with fault after fault for a 3 month old £1200 product.
Appreciate the support in advance,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You really have no choice here sorry ;-{
You’ll need to ship it to Apple to be looked at again.
But before you do that! You need to show them the defect. The first step is to simplify the OS and apps config remove as much as you can of any auto loading apps and make sure your OS is uptodate.
Now install this app TG Pro. you will need the full version here. That gets you logging. Enable it:
Hopefully you can collect enough events that can clearly show the problem. Now the fun part as you want to print out a nice spreadsheet & graph so its plan as day whats happening. Make note at each timepoint what app is being used.
If you can capture an Activity Monitor diagnostic at the time point you encounter the event. Locate it under the Activity Monitor menu: View > Run System Diagnostics…
Printout the TG Pro files and place a folder on the desktop where it can be seen by the tech a folder with the files. If you have a throw away thumb drive make a copy of the files on it and tape it with your printouts in a folder with your name and systems S/N on it.
Of course may a backup of all of your stuff and this as well and delete anything sensitive.
I would even have a friend witness you packing it up to ship your system off. As you can’t go directly to an Apple Store right now.
If you get it back without anything done or even if they say they fixed it and it clearly isn’t working again. Its time to collect your rapid paperwork either get your money back or get another system as this one is a lemon.
Let us know how it goes!
这个答案有帮助吗?
得分 1
1条评论:
I'd love to see what you pull together as well, post it here as well 在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
JiLi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 226
