跳转到主内容
A compilation of guides for counter-top and handheld blender repair.
346 个问题 查看全部
Hand Blender broke unexpectedly (CRUX All-in-One Hand Blender)
My CRUX All-in-One Hand Blender (CRUX003) broke whilst in use. I was blitzing oats into oat flour at the time and so thought some of the dust may have got into the system, but I have since taken off the outer ‘shell’ and blown a hairdryer over it and it hasn’t helped. I know very little about electronics but would love to fix this rather than have to chuck it out and buy a new one. I’ve attached pictures of it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @zoemdd ,
How long was the blender in continual operation before it stopped working?
A lot of stick blenders’ instruction manuals say that you should only run them in ~30 second bursts and then pause for a short while to allow them to cool, to prevent the motor from overheating and burning out.
The user manual for your blender also seems to indicate that ~30 seconds is the maximum running time for continual use before pausing.
Nothing looks untoward on the circuit board, so you may have to test the actual motor winding using a DMM (digital multimeter - Ohmmeter function) to see if it is still OK. You would need to disconnect the motor wiring from the circuit board so as to not get confused as to what you’re actually reading on the DMM. Always disconnect the power from a device when testing using an Ohmmeter
Having a sniff of the motor and deciding whether it has a burnt smell or not might also give a clue.
If the motor is burnt out you may be able to find a replacement motor by searching online using the motor’s model number. I can’t make out more the ARS 79? from the images but you should be able to see the complete number.
If the motor winding tests OK then you will have to do point to point static testing i.e. without the power connected, from the power cord plug through the circuit board and to the motor using an Ohmmeter to try and locate what the problem is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zoe D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 889
