跳转到主内容
为各种船只提供维修指南和支持。
How do I remove circuit board from housing
The ECU from new cat engine got the pins wet and needs new plugs. The circuit board is glued to the housing tho and I’m not sure how to remove it
Suggestions / tips are welcome
Update (05/09/2020)
all the info I have on unit
they are very new so no old ones around
I’ll have to try that.. cat wanting like 10k for one
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
WOW! Thats going to be interesting to fix. Even if you get the board out, you wont be able to fix this without the right parts and tools. Looks like some of the pins are corroded away. You can clean the plug with isopropyl, 99%. Use a tooth brush or small paint brush. This will clean up the area to see how bad the damage is. Do that and post updated photos.
这个答案有帮助吗?
得分 0
6条评论:
I have new plugs already problem is I can’t access back side of board to desolder old ones and install new ones :( hence wondering how to remove board
完成的
Pins in the plus are formed as part of plug so they are not removable individuality
完成的
@chewychunga Whats on the other side? Would the board be attached to anything in the back?
完成的
@casp3rtech it’s a cast aluminum plate with some fins for heat and a tube running across (for fuel so I think there’s a temp sensor on inside) but no mounts or anything
完成的
@chewychunga well if it was me in this situation, I would try everything to get it out since it's already bad, nothing worst can happen. Make sure there is nothing on the other side holding the board to the housing and use a heat gun on one edge and try to push a small flat flexible plastic under the board and see if it comes loose. If it does then just do that carefully around the whole board. Can even try some playing cards at first to get an idea of what's going on under the board. If you're lucky, the board might be held in place just in the edges. If you could get your hands on an old unit and just tear it apart and see how its bonded then you can know how to remove your board without any damages. Unless the manufacturer will tell you how to get it done?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Mat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 914
