跳转到主内容
This Sony 60-inch television produces natural color and outstanding brightness due to 3LCD technology. The Sony WEGA Engine used in this Sony projection television gives you complete picture clarity from any compatible video source by minimizing the digital-to-analog conversion process.
10 个问题 查看全部
red led blink 7 times
I have a Sony kdf that keeps turning off after 1-2 mintutes of viewing and power light blinks afterwards . Any suggestions to what could be wrong with it and how to fix it?
Self check
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
If you have a Sony KDL-E60A20 (not sure as you didn’t specify the model number) a 7 blink error code indicates an audio error and the TV will shut down.
The problem may be in the KD board or the GM board.
Here are some images taken from the service manual that shows the error codes etc.
(click on image to enlarge for better viewing)
The manual has full schematics which should help to find the problem.
Be patient when trying to download the manual. After you have clicked on the reCAPTCHA checkbox below the Document preview and then clicked on Go to Download, it takes a little while to find the file and change from processing to Download. This is the link
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marwen bouzguenda 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 8,184
