跳转到主内容
The Google Pixelbook Go is a premium Chromebook from Google, featuring a durable magnesium clamshell with minimalist design. Released in 2019. Model number: GA00521-US.
6 个问题 查看全部
Replace battery pixelbook go
Hi, I read the excellent aryicle explaining how to remove the back cover of a pixelbook go. Since the battery is glued to the back, I’m assuming that the best way to replace the battery is teplacing the whole back cover. Is that correct? If it is, where can one find a replacement back cover? Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
Hello! Did you happen to figure this out?
这个答案有帮助吗?
得分 0
添加一条评论
It’s extremely difficult to remove the cells from bottom cover so yes, replacing the whole battery/bottom cover assembly is the way to go. You can find cheap parts on eBay etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alessandro.gherardi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,390
