跳转到主内容
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 个问题 查看全部
My joystick doesn’t work anymore what should I do to fix it?
in a fit of gaming induced rage I decided it would be a good idea to slam the controller against my knee. It feels like it’s not attached and won’t stay in the middle will I need to buy a new controller or can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Best bet would be to pick up a cheap Torx t8 security screw driver and take the screws off the controller and try and reseat the controller stick. There are two screws in each handle and one hidden behind the label on the battery pack.
There are many tutorials online about how to do it without breaking your controller, which is very hard stuff up, you'll be fine.
My right joystick is slightly moving up
https://gaming.stackexchange.com/questio...
Hope my answer helps you some way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas scheonbachler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 658
