跳转到主内容
加入维修社区 - 创建账户
Google Pixel 系列第三代中的其中一隻。Pixel 3a為系列中主打中低價位的一員,其中,鏡頭型號與同系列旗艦款式同款。2019年五月發布,有全黑、純白、淡紫三種顏色(前兩者電源鍵為橙色,紫色為黃色)。
Replacement screen not working
I replaced my Pixel 3a screen and the new screen is glitchy:
  1. The ambient display shows at full brightness and when transitioning from ambient display to lock screen, the screen flashes white at full brightness.
  2. The keyboard requires significantly more pressure than on previous screen. Therefore, when typing quickly, many keys are wrong or missed.
When I disable the ambient display, the flashing goes away — I can press the lock button and the lock screen appears without issue.
How can I diagnose the cause? The previous screen was cracked, but otherwise fine, so I assume it is the new screen. But, is it possible that something else is causing the problem? I followed the directions on iFixit and encountered no problems.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like a defective screen or it’s not seated properly. If you cheaped out and bought one from eBay, Amazon, Craigslist, Wish, or AliExpress, that’s why. They don’t specialize in screens and anyone can sell junk parts for dirt cheap.
这个答案有帮助吗?
得分 1
4条评论:
Thanks. Understood — I bought it from iFixit (and paid the premium) exactly because I was afraid of a bad part. Any thoughts on how to distinguish a bad screen from a bad seating? Do these specific symptoms make sense for a bad seating? It’s not flaky — it’s very reliable in its problematic behavior.
完成的
@ymandelb good I'm glad you bought from a reputable source. The only way to distinguish between a bad display and improper seating is to disconnect and reconnect the display. Inspect the connectors and cables while you're at it. If it's still acting up, it's most likely a defective display.
完成的
I reseated it and checked the cable and connector. Everything looked in order, yet the reseating had no effect. I'll try to get a replacement from iFixit and see if that does the trick.
完成的
@ymandelb
Here's ifixit's returns policy (there's a contact us link towards the bottom of the page).
Perhaps you should temporarily reconnect the old screen (presumably still working just cracked) to verify that the new screen is the problem just in case something else happened during the repair
完成的
添加一条评论
添加你的答案
Y Mandelbaum 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 776
