跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Will a 7 battery plug into an 8 plus?
I’ve been asked to look at an iPhone 8 Plus that won’t charge or turn on. Checking the battery I assume is the first course of action. But, the only spare battery I have kicking around is out of an iPhone 7. Are the connectors the same? Would I be able to plug the 7 battery into the 8+ just to test it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The battery connector is different so unfortunately they can't be plugged into a different model.
First course of action for me is to check if the charging cable is plugging in snugly. If not with a gap I then clean the charging socket of any foreign material or gunk and see if it charges.
A USB ammeter (which can be bought relatively cheap on eBay) will help to diagnose if charging socket is working at all.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jenn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
