跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
After charging to 100% iPad turns off due to low battery
Hey guys,
Recently I have problems with my iPad mini 4 Wi-FI.
After charging to 100% battery, iPad turns itself off with low battery indicator. If i try to turn it on just after - it still shows low battery and won’t start. After few tries it allows me to turn on again, it boots to the main screen, I can see that battery is at 100%, but if I try to do anything it shuts off again with the same low battery indicator.
It usually takes several tries (even more than 10) to get it running again.
Do you have any idea what could be wrong? I never let it drain to 0% and turn it off by itself.
Appreciate any help!
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Was it ever repaired? Can you check battery health? You can use software such as 3UTools for Windows or Coconut battery for Mac to check battery health. Tell us what the design capacity is at.
完成的
Thank you. The iPad was never repaired, there were no issues with it ever, until this one. I checked the device via 3UT, it says that the battery life is as 78%.
The battery life itself is not a problem for me, the issue is that if it is charged at 100% it's almost impossible to turn on the device. While it is connected to PC or to the charger it is working fine. If i unplug it at 100% it turns off due to low battery error all the time.
If the battery is lower than 100%, even 98-99% I can turn it on without problems as well.
I have no idea what to do.
完成的
Battery temp is 30.8 C, charge times is 1256. Capacity at this point is 3915 / 5018 mAh.
完成的
添加一条评论
2个答案
最有帮助的答案
Heat the back of the iPad with a hairdryer or heater. This seems to work.
这个答案有帮助吗?
得分 2
3条评论:
I get this problem all the time when I accidentally charge to 100%. Usually, I can hold the power button and the home button at the same time and the Apple logo appears. This time it didn't work. Your tip to heat with a hairdryer followed by the power/home button combo did the trick. Thanks!
完成的
Wow. My ipad was in effect left plugged in as it went from 100% to 0% within minutes of being unplugged. Tongue in cheek i heated the back with a hairdryer and in now works as it should. Holds charge well and slowly discharges with use. Thank you. I can now move it around the house as designed.
完成的
Stuart Barlow? Is the battery still behaving itself? I have the same issue with my rather old iPad Air 2 & after doing a search, it seems lots of people over the years have had problems with this. I’m looking for a permanent solution, find it hard to believe the hairdryer trick will be it 🤷‍♀️ Lol
完成的
添加一条评论
I see that your battery health is under 80%. From my personal experience with repairs, the majority of apple products under 85% battery health suffer symptoms like this. The battery will need replaced to remedy this issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maciej K. 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 181
总计 8,603
