跳转到主内容
加入维修社区 - 创建账户
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Random iPad Air Screen Locks
I recently replaced the screen/digitizer and battery on my wife’s iPad Air. Everything seems to work normally except the screen will turn off and lock at random times, including while my wife is using it. It has even turned off multiple times in a row (in a matter of seconds). She has to hit the Home button and enter her pin to get back in. It appears to happen more often when the battery is low (below about 30%?). I’ve tried turning off Lock/Unlock and setting Auto-lock to Never with no effect. Any thoughts on what might be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think it may be an issue with the cable for the power/lock button cable or connector. You’ll have to open it back up to inspect it. Look for tears or folds in the cables or damaged, bent pins on the board or cable itself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Barry 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 20
总计 302
