MacBook Pro not turning on?
Hello!
I have a MacBook Pro A1707
It’s a 15inch with touchbar I believe mid 2016-2017
I just replaced the battery and it won’t cut on at all.
I went out and bought a brand new charger and it still won’t cut on
No lights, no fans, nothing at all.
Ive already tried multiple things like Cntrl + Option + Shift, power button.
Any ideas?
8条评论
Who's battery did you use and did you follow the iFixit guide?
由 DanJ 完成的
I used one off Amazon, I can get the name of it if you’d like. And yes I followed the guide
由 annelise mitchell 完成的
Did you happen to find out what went wrong? I am having the same issue.
由 Misty I. 完成的
@Misty I. - did you replace the battery yet? 2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
由 DanJ 完成的
@Dan - yes, I did. It started to work after I waited for about an hour. I am not sure if it's because my motherboard was somehow drained or had a very low power as I worked on it. I spent several hours since I also replaced both speakers and struggled with the glue.
由 Misty I. 完成的
显示更多的3条评论
