跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
How do I know if it’s an iPhone X or Xs
Hey guys, recently acquired an Iphone from a family member with a swollen battery (don’t want to risk turning it on) and was wondering how can I identify what model it is without turning it on? (not even sure if it can).
Any Ideas?
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Visually identifiable:
X: Symmetric bottom
Xs: additional antenna slits that cut the bottom left grills short.
这个答案有帮助吗?
得分 2
添加一条评论
Hi Daniel,
Pop out the sim tray, the IMEI of the device should be laser etched into it. use https://www.imei.info/ to ascertain which model your family member has.
  • if you do decide the replace the battery yourself, have a bucket of sand at the ready. It’s one of the best things to quel that type of fire.
My honest opinion would be to take it to apple. normally they would take the phone from you, replacing it for the cost of a battery replacement.
Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I’ve done plenty swollen battery replacements so far so I’m sure I can handle the challenge. Our local and only apple reseller won’t accept it because it was badly damaged in an attempted mugging. Broke the screen and back panel, and my uncle got then replaced at a very low quality repair service (no TrueTone). So if I want to salvage it I will have to do it myself.
完成的
添加一条评论
添加你的答案
Daniel Guerriero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 483
