跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
What work do I need done?
On my screen, at the bottom right corner there’s a black splotch/blob. It started small and slowly is growing, and now my phone has the ghost touch. Whenever I try to type it’ll start pressing all over the screen. What will fix it? And how much will it cost? Are stores even open now for it to get repaired, due to the coronavirus?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
broken oled you will need to replace the display on an xs max is can get pricey i would just call around to the local repair shops they should still be open (at least around my area they are )
这个答案有帮助吗?
得分 0
添加一条评论
Hi Denise,
Sounds like your display is faulty, depending on when you purchased the device you may still be under warranty. First step would be to visit apple.com/support and check warranty status. If there’s no other damage to it it may well be covered and they can walk you through the process.
If not you can get it fixed through Apple if you’d like at a cost. It varies between countries a little but visiting https://support.apple.com/iphone/repair/... should give you some idea.
Given that we’re on iFixit, if you’re confident with electronics repair / can follow the guides and want to give it a go. check out https://www.ifixit.com/Store/iPhone/iPho... It sounds like a screen replacement would sort the issue.
Hope this helps!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Denise Nguimdoh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 130
