跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
computer does operate without charging cable
QUICK BACK STORY: Wife spilled water and went into the laptop from the backside. Did not shutoff immediately- shutoff approx 1min later with a flicker then turning off. She immediately tried using a hair drier to it for only a minute. She did put on charger thinking it would boot. This is when she got me and I immediately put the laptop in an A (Tent) and let sit for 48hrs- not attached to power source.
AFTER 48HRS: I tried to power up the laptop without power and it went through a partial boot then shut back down; Attached charger and still nothing. FROM THERE—
  • Complete motherboard teardown and cleaned the board with 91% alcohol (highest percentage I can get during NYC Quarantine amidst COVID-19). Located water damage on the backside of the board. Cleaned the board completely with alcohol and reassembled. Unit powered up while on power source; powers off immediately once disconnected. Wife tried editing a video in Adobe Premier Pro and the laptop powers down while editing, even while on the power source…
  • I’ve run Diagnostics — “The battery will need to be replaced soon.”
  • I’ve done an SMS & PRAM Reset, both with no results.
Any/all help will be greatly appreciated. I’m pretty technically savvy. Willing to test what I’m capable of.
Update (04/15/2020)
**UPDATE** — Changed out the logic board as per. what @danj had suggested may be the problem. The issue remains. I again SMS/PRAM Reset, but nothing. The laptop still shuts off when detached from the power source; also it restarts when in load while using Adobe Premiere Pro. No fan sound of heavy load either- diagnostic does not say the fan is failing.
Some additional info that may be of use [?] ;
  • Laptop does not fully boot when attached to an off-brand Apple Mag Charger. It almost loads all the way, but powers off.
  • When laptop is on the power-source it DOES NOT move from 97% (it actually said 99% with the other logic board).
Any/all info or advice will be hugely appreciated. Thanks.
Update (04/18/2020)
PROBLEM WAS FIXED. Given the battery information, @danj ‘s advice to change the battery fixed the problem completely.
Gave the original Logic Board one last alcohol bath; swapped out the battery. Problem was fixed. I’m guessing the water shorted out the what was left of the life of the battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Updated question per some suggestions.
完成的
While it was in need of replacement it look like the battery is also too far gone.
完成的
@danj Added the Screenshot from Coconut.
完成的
Wow! You take the hill! I ‘ve never seen anyone get even close to 2,000 cycles! And you even did more! hitting 2,109.
Yep, its time for a new battery! Determine battery cycle count for Mac notebooks As you can see 1,000 is the expected life.
Even after you get the new battery, you really need to change your work flow as this system shouldn't have gone that far. You appear to run it to the ground and then charge, and then repeat! This is not the expected use model. While it is a portable system the idea is you are still plugging in as often as you can. I even have a charger by my bed for my iPad.
完成的
添加一条评论
1个答案
已选择的解决方案
Your system logic board needs repairs. The charging logic is damaged.
As far as why your wife’s using Adobe Premier Pro to edit a vid having the system shut down also makes sense!
What many people don’t know is the needed power for heavy apps like Adobe Premier Pro can’t run off the MagSafe alone. The charger is just that a charger not a replacement for a dead battery or when the battery is unable to power the system. Sure, low power apps will work, its when you push the system too far it will fail.
Are you able to get to Brooklyn? Give Louis a call Rossmann Repair Group I’m sure he can help you.
这个答案有帮助吗?
得分 3
5条评论:
Thanks for that info Dan. It couldn’t have come at a better time. You have just saved me a couple of hours work regarding a 2012 Mac running Adobe Photoshop 2020
完成的
Good chance it's failed completely? Or might there be water damage that alcohol may fix?
完成的
Nevermind. Did a complete teardown and no success. Thanks for your help. I can fix myself. Now just gotta get a new board.
完成的
@bobbyblackk - Please give Louis a call he will do you right!
完成的
@danj Thanks for all your help. The battery swap was the answer. Original logic board was fine after I cleaned up the water damage. Running like a lightly used Bentley again.
完成的
添加一条评论
添加你的答案
Bobby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 101
