Turn signals come on when I hit my brakes.
Okay, so when I press on my brakes both turn signals come on in the dash and up front. When I lift my foot off the brakes the lights shut off. My tunsignals do not work at all. They don't blink when I hit the turn signals. I'm not really sure if I have normal brake lights because turn signals over ride brake lights. It isnt the brake light controller that attaches to the back of the brake pedal. I'm assuming it is an electrical gremlin somewhere.
@michaeltrotter ...sounds like a crossed connection. either a shorted relay or switch of some sort. (bridged ic? lol computer joke) if it were a fuse, you wouldnt have either one working. they are apparently feeding off of the same bus/ harness so id start there. it could also be the plc programming but im sure if it was, there would be alot more malfunctioning then just your brake and signal lights. im interested so post back with what you find please. good luck
heres a link to something similar...ish:
wiring problems with turn signals and running lights,.,.
由 jostewcrew 完成的
