跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Why is iPad Air (A1474) screen unresponsive
My iPad was run over by a car 2 months ago but ended up slightly dented and needed a new LCD screen. I just replaced the LCD screen and kept the original digitizer and it was working just fine for about a day. It randomly just stopped being responsive to touch.
The home button stopped working as well, so I replaced the digitizer with a new one (purchased from RepairPartsUSA) only for the touch to still be unresponsive but home button works.
I then went back replaced the new digitizer with the original to see if it made a difference and the home button worked again just fine but still no touch response.
I made sure all cables were properly connected and lined up correctly. I even did a hard reset/restore and update and still nothing.
Should I try a new digitizer just incase the two I have are just faulty or should I chop it up to being another issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Check around where the connectors are you could have knocked off a component.
完成的
@tech_ni I checked, but I am not seeing anything missing or out of place
完成的
添加一条评论
1个答案
As mentioned by @tech_ni above, check that there aren’t any missing components by the connectors. Usually devices can encounter heavy damage, especially when run over by vehicles. You could try another digitizer, I recommend Mobile Sentrix, but odds are the board suffered damage which might be repairable. Check your local repair shops if they specialize in microsoldering.
这个答案有帮助吗?
得分 0
1条评论:
Checked again and didnt't see any missing components. I had an otterbox case on it, but I'm not sure if that would've helped protect against internal damage - the visible damage was light denting along the top right corner so the screen was lifting along the right side. The touch response went out when I was pressing along that area to get the screen to adhere, so maybe that is a sign that there is damage to the board
完成的
添加一条评论
添加你的答案
Mariah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 152
