跳转到主内容
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
82 个问题 查看全部
Screen shuts off with pressure to bottom part of bezel
When there is any amount of pressure against the bottom part of the bezel that surrounds the screen it will shut off but immediately turn back once the pressure is removed. I can still hear audio while this occurs.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,,
What is the full model number of the laptop?
It appears as though the LVDS cable is either loose or it may be damaged where it passes through the hinge to get from the motherboard to the display panel.
In either case the laptop will have to be dis-assembled (at least partially) so that the cable connection at the display panel can be inspected and the cable itself can be checked for any damage.
If you search on YouTube for Acer (insert full model number) teardown or screen replacement, hopefully there may be some videos that will help with the dis-assembly process.
If the cable is faulty there may be a part number stamped on the cable. Use that number to search for a replacement cable or search for Acer (insert full model number) LVDS cable to get results for suppliers.
这个答案有帮助吗?
得分 0
2条评论:
Model #: N16Q2
Thanks for the help. I disconnected/reconnected the screen to no avail. I guess I need a new screen.
完成的
@Rick James ,
Did you check the cable for any damage, you didn't say?
Try pressing on the hinge (not sure whether left or right for your model) and not the bezel and check what happens on the display.
完成的
添加一条评论
添加你的答案
Rick James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 122
